The script execution was aborted as it exceeded the timeout value. To see the output of default.xsf and autoexec.xsf, please use the CLI command "show script output [default | autoexec]". The line number where the script aborted is displayed on the session.
If this is unexpected, either reduce the length of the script or increase the timeout value using the CLI command "configure script timeout <time>".
Warning
Aborting the loading of %filename% as it exceeded %timeout% seconds.
| Name | Type |
| filename | String |
| timeout | uInt |
